Hi guys,
My r33 gts-t's reverse lights aren't working and it looks like the switch is screwed...
Anyway, I've tried to take the old switch of the gearbox but I can't get a spanner in there to get the damn thing off. Do I have to drop the gearbox to get the switch off? Is there any other way? Has anyone here tried before?
wil..
https://www.sau.com.au/forums/topic/43300-r33-reverse-light-switch/
  • 3 weeks later...
  • 3 weeks later...
Turns out there is no real easy way of getting to the little bugger.
My mechanic had to drop the gearbox, and even then he couldn't get the thing out. Ended up cutting the wires and using a socket to get it out.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
