Hi all,
Yesterday morning I checked the coolant and it had some brown discolouration (see pic).
I have drained the radiator and flushed it out with water.
A large amount of this stuff came out.
Whilst bleeding the coolant, more brown stuff came out.
I closed it off and revved the engine, where upon bits were coming up through the radiator.
I drove the car around for roughly 30-40 minutes, and re-checked when cool. There was minimal brown stuff inside the radiator (pretty much as much as you can see in the pic).
Notes on old mate 'brown stuff':
- It floats
- I couldn't work out the smell, it didn't smell like oil. I run e85 so I'm not sure whether it could be that.
- It has a very silky feel to it
Other notes:
There's no condensation or coolant coming through the exhaust
The oil level did not seem to drop at all, nor has it dropped over the last month
Any help or opinions would be greatly appreciated!
Pic: http://i991.photobucket.com/albums/af34/Godsillah/DSC03579_zpsd7bbd9a2.jpg
what i would do
get some radiator flush..run it through the system as per instructions with heater on.....drain....
disconnect top radiator hose and put a hose in the top of the radiator...run the engine with heater on so water form the hose flushes through and drains onto ground from disconnected hose.......do this till water looks fresh....could take a while...
then fill with coolant and drive....if problem persists you may have another issue
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
