Hey guys, up for sale is my daily.
Heres some copy pasta from the carsales ad!
-Reluctantly up for sale is my Peugeot 306 GTi6 The GTi6 is Peugeots flagship 306. Boasting a sporty 123kw (165hp) 16valve 2.0L engine, this car is incredibly quick and nimble.
-Mated to the powerhouse is a motorsport inspired close ratio 6 Speed Transmission. This box keeps the engine in its powerband at virtually all times. You will always have power when you need it.
-The GTi6 has been regarded as one of the best handling hot hatches of the 90s, with an excellently balanced chassis and suspension setup the car feels like a go kart and sticks to the road. Body roll is non existant.
-This example has an aftermarket exhaust system, intake and headunit stereo.
-The mechanics, drivetrain and electrics of this car are in perfect condition. A new battery, coil packs and MAP sensor have been fitted whilst in my ownership.
-I have serviced the car every 5000ks and it has just recieved a service.
-In honesty, there is some cosmetic faults, being that the car is nearing 15 years of age. These include some flaking paint on the roof, some interior tears and a scratch on the front quarter panel. There is also some minor parking dings that are very hard to notice.
*(Please see the pictures for the cosmetic faults)*
-Also, the glovebox lock has broke, and the drivers side door lock has seized. (The door still locks from the passenger side).
-Besides these minor issues, the car is in great condition and would be the perfect car for the city driver and mountain driver alike.
-This car is fantastic on fuel. I have only used 98RON Premium fuel in the car since purchase.
$6000 ono ~ Rego till 30th JUNE 2014 ~ P Plate Legal
Send me a text 0421447425. I cant always pick up for calls so a text is best.
The car is located in NEWCASTLE NSW
No swaps
Cheers
Edited by Bennis
https://www.sau.com.au/forums/topic/434621-nsw-peugeot-306-gti6/
  • 3 weeks later...
  • 1 month later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
