Bought a timing belt kit with waterpump from ebay the other day. The kit was described as "Gates racing timing belt kit + GMB waterpump". We paid a bit extra for this kit because of the GMB pump.
It arrived yesterday, and was all in a single box that was badged as a Gates waterpump (no mention of the rest of the kit) for a Commodore. The waterpump has no brand name or manufacture country on it, and was in an unmarked plastic bag in the box, along with the other bits.We stripped the front of the engine to fit. Replaced all seals, then went to fit the water pump - it doesn't fit. The pump is bolted in by a variety of bolts - several 14mm & 12mm headed bolts and one 10mm headed bolt. The original pump has a slotted hole for the 10mm head bolt - obviously to suit several different blocks. The photo on the ebay ad clearly shows this slotted hole as well, but the pump supplied has a round hole (ie the bolt can only go in one place) which (of course) doesn't line up with the hole in the block. This is the new pump -
https://www.dropbox.com/s/ngfp86msag8emsr/2013-11-14%2019.01.26.jpg
the hole is the second from the left at the top of the pump.
The f'wits also sent 2 idler bearings instead of an idler & a tensioner.
Anyone know if a GMB waterpump has any markings cast into it - ie brand name, made in Japan etc - or what the GMP part number is? I don't think this is a GMB pump, and is a chinese replica.
Edited by GeeDod
https://www.sau.com.au/forums/topic/435021-is-this-a-gmb-waterpump/
Kit was $290 shipped. Ended up buying a pump & tensioner locally - ebay seller agreed (on the phone) to re-imburse when I send his bits back. If he doesn't I'll lodge a Paypal complaint - prick sent me a cheap pump when he advertised a GMB, and it didn't fit anyway, as well as sending 2 idlers & no tensioner.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
