Hey guys,
Just thought i would share this with you all. This is a clip of me in Last weekends Temora 1000, I ranked 10th Overall with a time of 21.82seconds at 248.37kph. For those interested
Was an awesome event, would highly recommend coming to this. Would love to see more GTR's out there
There were 5 GTR's in the event, All 5 were placed in the top 10, 2 x R32's and 3 x R35's, mine was the slowest and still made the top 10.
Cheers
Kam
http://www.youtube.com/watch?v=BOQcdx6Pvg8&feature=c4-overview&list=UUFDdQQUOqbeFC3ltH7W5Vag
Edited by psikazi
https://www.sau.com.au/forums/topic/435167-2013-temora-1000/
Nice one.
I was disappointed I couldn't make it there in the Stagea, but no ethanol servo's on the way. I would have been close to knocking you out of your 10th place I would hope... Next year. :P
A customer of mine James was up there in his silver Supra, managed 308kph but too much wheel spin to get better than 3rd or 4th I think. AWD wins on loose gravel. ;)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
