Hi skliner's
is there a test that can be done on my 33's induction piping to see if there are any leaks. What is this test specifically called. Can the test be done without running the motor (partially tested) is there a procedure my mechanic would use to check this......is there a procedure you guys use to check for a suspected 'leak in the system'? (saying "flooring it" probably won't be doing us any favours!!)
anyways.....Thanks again.
Hmm, I've heard of people blowing smoke into the induction system (without the car on !) so if there's a leak you can see the smoke comming out etc.. A bit dodgy though.
Maybe put a blanking plate on the inlet near/between the cross over pipe and plemum somehow, the take the AFM off and somehow plug and pressurise the system from there ??
Would be interesting to see ow they do it.
J
Found this while searching for a leak tester last night. Pretty useful, and I cant see how it wouldnt work either :D
http://www.vfaq.com/mods/ICtester.html
Interesting indeed but I think you will need to have the motor on TDC or otherwise if one of the intake valves are slightly open, then pressure will pressurise a cylinder and escape past the piston rings or into the exhaust if there is valve overlap!
thanx Jay, and thankyou Amaru.........that's exactly the expl. I was looking for!
u guys rock.
To those of you that have a proper after market mechanical Boost Gauge(BG), do you think that taking a reading from ur BG while idling, then switching off ur car and measuring the 'time' it takes to return to zero psi could be used as a leak indicator.
for example...my car might idle with a neg 20 (PSI, please) on the dial then return to '0' within 1 or 2 seconds.....should it creep back up to '0' more slowly?.....or is that about right (compared to yours)...or........is that indicating a leak.....or.........just proving to you that I'm actually very stupid?? (be nice)
crickey.....didn't consider that one!
I believe if u r refering to the piping, and trying to find a leak, u can spray somethin like start ya bastard on the piping, and if the revs raise a bit whilst u spray it, it indicated a leak somewhere. That what u do if u think an intercooler pipe is leaking.
hope that helps.
Great thread, ive often thought about testing for leaks
thanx Knore.....the reason for the thread is because when I first installed my GFB boost control (and proper gauge) and adjusted for 9 psi the car felt incredible...almost too good, if u know what I mean? My new gauge and the stock one seem to 'concur', so i am relatively confident that my readings can't be too far off (safe, at least). But the last 3 days i've noticed that the beautiful pull i had (not that f*****) pull!!) has gone. I do not speed, but the car gave me a nice push in the seat from 2000rpm with half throttle...no stress at all by the motor/turbo. It was doing it easy. It could be the petrol i'm using (always 98), or the GFB has stopped bleeding air so it feels like a stocker again.. Power is still there when I push it, just not down low....which is only where I like it (i'm a 60 to 80 kmh driver). Maybe I'll just have to play around with the bleed screw again, or wait till the petrol runs out and re-fill with expensomax. These beautiful Sklines have their good and bad days, don't they. Maybe I'll do nuthin, as it'll sort itself out???
hope that helps.
how innovative is that!!!!!!!!!?????????
thanx Knore.....the reason for the thread is because when I first installed my GFB boost control (and proper gauge) and adjusted for 9 psi the car felt incredible...almost too good, if u know what I mean? My new gauge and the stock one seem to 'concur', so i am relatively confident that my readings can't be too far off (safe, at least). But the last 3 days i've noticed that the beautiful pull i had (not that f*****) pull!!) has gone. I do not speed, but the car gave me a nice push in the seat from 2000rpm with half throttle...no stress at all by the motor/turbo. It was doing it easy. It could be the petrol i'm using (always 98), or the GFB has stopped bleeding air so it feels like a stocker again.. Power is still there when I push it, just not down low....which is only where I like it (i'm a 60 to 80 kmh driver). Maybe I'll just have to play around with the bleed screw again, or wait till the petrol runs out and re-fill with expensomax. These beautiful Sklines have their good and bad days, don't they. Maybe I'll do nuthin, at it'll sort itself out???
hehe there is two words i liked in that: Concurr and expensomax :P
Bleed valves tend to get some gunk buildup in them after awhile, which would obviously affect its operation. But by the sounds of it, its probably just fuel, check all your hose clamps and do the normal inspection. It will probably go back to normal. You done a oil/plug/fuel filter change recently? Not that this would alter boost, but it does make a big difference in terms of smoothness in power delivery.
Hey Knore.....and thanx man.
yeah, you're probably right (i concur), i'll just wait till this mobil stuff flushes out and then go back to wallet-o-max. Thanx again, I'll do what u suggested though.
Hi skliner's
Are tou trying to actually find the location of a leak or see if there is one? If we are trying see if there is a leak, we use 2 boost gauges. One plumbed in at the turbo compressor outlet and one plumbed in at the plenum. If there is a leak there is a big difference in the boost readings. Particularly at low boost levels. Much more than the simple resistance of the pipework and intercooler.
Hope that helps :rant:
well, er good question Skid, I guess both...
so, in actual fact, you are measuring pressure differential (between two points) to determine if and how much of a leak there is!!?
you're ace....will get hold of another gauge this evening. ($45.00 for a Speco at repco.....should be able to handle that!)
mate if your are getting 9psi at the manifold then your have got more than 14psi at the turbo, tri and hook your boost gauge up just b4 the boost controller
__________________
[OBEASE] ITS SO FAT ITS OBEASE
i took this from "MacBoost" in the forced indy section from last year...is this true? this much pressure differential? I'd better re-plumb my Boost Gauge...(?)
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
