Series 2 RB25DET comes with everything minus turbo $1200
R33 RB25DET full manual conversion minus flywheel and clutch $1300
Power FC model number ECR33010-1489 comes with hand controller $1100
Rear cradle comes with diff, shafts and hicas lock bar no brakes $400
X force exhaust system 3 inch stainless steel comes with 3 inch hollowed out cat $300 ono
Window regulators drivers side and passenger side out of s1 and a s2 passengers side $50 each (not sure if s2 and s1 regulators are different)
series 2 dash very good condition comes with air bag $150
door glasses $50 each
S1 dash good condition $20
Overflow bottle good condition $20
Washer bottle good condition $20
Rear parcel shelf good condition $20
Rear coil overs (only) Sustec pro tanabes good condition no leaks $300
Series 2 seats good condition six pack of corona
Rear right tail light (drivers side) good condition $20
Silver door good condition has handle and lock but no window or regulator $20
Best way to contact us is on our mobiles as not always near computer
Do have a few other parts that may not be listed let us know what you need and we will let you know
Matt 0490 038 063 or Daniel 0457 481 022
https://www.sau.com.au/forums/topic/435438-for-sale-r33-s2-parts/
  • 2 months later...
  • 2 months later...
  • 4 weeks later...
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
