Hey guys,
I know many people have asked this question but I haven't been able to find the right answer I need as my question is a little different!
I got a microtech ltx-12 and it comes with an igniter inbuilt in it, hence I don't need the series 1 igniter...
My question is will GTR coil packs screw into my rb25det head?
Ps: please don't answer my question with reference to the inbuilt igniter stuff... All I'm worried about is that they physically won't fit into the head. :)
Thanks in advance.
https://www.sau.com.au/forums/topic/435600-gtr-coil-packs-on-r33-gts-t/
Have you considered running external coils and leads? The bosch coils microtech sell with the ltx12s seem to work alright
Best thing you can do is run over the microtech and buy a decent ecu. The technology in a nintendo gameboy would be more advanced.
I agree about the microtech but that all I got at the moment - saving up to get my rb30det setup! ;)
I'm thinking of just running external ls1 or ls2 coils and mount them on the firewall
LS1/2 coils have inbuilt ignitors so they won't work with your microtech. They are great option for coils though. Not sure if you can send the ecu back and get the inbuilt ignitors disabled. Just another thing they would charge you for though
Unfortunately they can't disable the igniters - guess that means I got no option but s1 rb25det coil packs :(
or i can use the bosch ones that are for sale on the microtech website
http://microtechefi.com/index.php?route=product/product&path=36&product_id=62
Anybody ever used these??? Not sure if they are decent quality?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
