I got my results recently and wanted to confirm if these AFR's are ok.
Car is stock apart from some Jap ECU (Impul) and Cat back exhaust.
Made 150kw and 250 nm
my afr's are as follows:
13:1 @ 2,800rpm @ 6psi
12.5:1 @ 3,500 rpm @ 6psi
12:1 @ 3,750 rpm @ 6 psi
11.5:1 @4,750 @ 6.5psi
11:1 @ 5,100 rpm @ 7psi
10.5:1 @ 6,250 rpm @ 6 psi
150kw @ 5,750rpm
250nm @ 5,250rpm
I wish to put in a bleed valve (GFB) and raise the boost to a constant 7-8psi, with the above AFR's do you think I still have a safety margin.
Car was not detonating on the dyno, i just want to make sure I wont cause issues if I put in an MBC, especially if my boost comes on earlier where i am the leanest with regard to AFR's.
I do have an aftermarket Jap ecu (Impul) which is for 100 octane i think. So by running 98 ron i was cautious and had it Dynoed after turning the boost down from 12psi (set in Japan) to 6-7psi.
Any advice appreciated guys.
https://www.sau.com.au/forums/topic/436003-afrs-rb25det-neo/
It is going quite rich which is expected on an untuned ecu.
You cant just aim for a specific afr though, you have to give the engine what it wants, which varies between engines.
You are also forgetting timing. You cant guess what thats doing.
Why didnt yiu just crank the boost whule it was on the dyno?
It was dynoed to check for timing issues as well and seemed to hold up ok. definitely going to tune it in the future. Just need funds as I just imported the car and also had major service done. Wanted to steady the boost at 7psi but wasn't sure if it's safe to do so as it leans a bit in lower rev range and GFB advertise for their MBC to bring boost on earlier so need to know how safe it is for me to do that. Didn't have a boost controller when it was dynoed so couldn't experiment at the time. Edited by Bugzs15
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
