OK, In the 3+ years since I got my 33, I have Gathered WAY TOO MUCH STUFF!
This is not all of it but it's a start, Prices are ono...
Located in Canberra, most can be posted at buyers expense, local pickup preferred.
Buy my Stuff and Things!
R33 S1 Turbo, Minimal shaft play but condition unknown as unused by me. $150. SOLD.
R33 S2 Turbo, Minimal shaft play but condition unknown as unused by me. $180.
R33 side indicators. $15 / pair... (more than 1 pair available)
Stock Rubber intake Pipe for GTS-t $15 (more than 1 available)
R33 Coupe Rear Garnish (Clear) $50.00
Various NISSAN Relays $10 each.
GTR BOV $80 (More than 1 Available) 1 SOLD Pending Payment/Pickup.
Some piping for GTR Bov also.
GTS-t Bov $40
R33 Crossover J pipe $20 (more than 1 available)
Stock R33 GTS-t Dump $20
New Never Used Stainless Split Dump Pipe $80
Stock R33 GTS-t Frontpipe and Gutted Cat $20
3" GTS-t Frontpipe larger section welded in the middle. Ugly but Effective. $40
Stock Series 2 R33 Coilpacks $80 / set of 6 (more than 1 set available)
Stock R33 Side Mount Cooler $50.
R33 4door Tail lights and Garnish - Both Series 1 and Series 2.
R33 Coupe Series 2 Wing (White) $100
R33 4door Wing (Silver) $100
R33 GTS-t Airbox and Snorkle $100
**More will be added in time...
**R33 GTS-t RB25DET Rocker Covers $100 pair, I might even clean them for you.
**R33 GTS-t Stock ECUs Series 1 and Series 2... $100 Each.
If it's Not Listed, I may have one... Just ask.
PM is best. Pics can be provided.
https://www.sau.com.au/forums/topic/436360-r33-4door-bits-and-much-more/
10% Off asking prices til the New Year.
GTR BOV $80 (More than 1 Available) 1 SOLD Pending Payment/Pickup. :whistling:
GTS-t Bov $40
Stock R33 GTS-t Frontpipe and Gutted Cat $20 SOLD.
3" GTS-t Frontpipe larger section welded in the middle. Ugly but Effective. $40 SOLD.
**R33 GTS-t Stock ECU Series 2... $100
Series 1 ECU SOLD.
All this^^^ Plus...
ARC Airbox for R33 GTS-t, comes with an old and a BRAND NEW ARC filter. $375 + $25 Postage.
KYB adjustable R33 GTS-t shocks, Front and Rear. $150 + postage.
Unsure of condition as I have never used them and will have to dig them out of the shed. No leaks last time I saw them.
Couple of pics...
post-78856-0-56333900-1389431420_thumb.jpg post-78856-0-98918800-1389431415_thumb.jpg
Also a set of 4 x R32 GTS-t rims painted Bronze-ish (backyard job), with center caps. $150 + postage.
Pic as they were when painted. (some scratches now, could do with a repaint)
How much for series 2 sedan lights
$200 with Garnish, $160 without. (plus Postage) ;)
KYB adjustable R33 GTS-t shocks, Front and Rear. $150 + postage. SOLD.
4 X R32 GTS-t Rims (Painted Backyard Bronze, could do with a touchup/redo) with center caps. $160
ARC Airbox to suit R33 GTS-t. $375
(with Old+New ARC Filters - $100 New)
R33 S2 Turbo, Minimal shaft play but condition unknown as unused by me. $180. Not available.
R33 Coupe Rear Garnish (Clear) $50.00 SOLD.
GTR BOV $80 (More than 1 Available) 1 SOLD Pending Payment/Pickup SOLD
R33 GTS-t Bov $40
Stock R34 GTT Side Mount Cooler --- Convince me to $ell.
R33 4door Tail lights and Garnish - Both Series 1 and Series 2. $160 a pair or $200 with Garnish
R33 RB25 Timing Belt Cover $30.
Series 1 ECU SOLD.
R31/RB30 Throttle Body $40.
R31 Stock Front Springs $30 pair.
R31 Wagon Rear Hard Springs $30 pair.
R31 Wagon Rear Stock Spring $30 pair. Available soon...
Located in Canberra. Can be Shipped at Buyers Expense.
Pics on request.
PM me is best...
  • 3 weeks later...
Update...
4 X R32 GTS-t Rims (Painted Backyard Bronze, could do with a touchup/redo) with center caps. $160 SOLD.
GTR BOV $80
R33 GTS-t Bov $40
New Never Used Stainless Split Dump Pipe $80 SOLD.
Stock Series 2 R33 Coilpacks $80 / set of 6 SOLD.
Series 1 ECU SOLD.
Pics on request.
PM me is best...
  • 3 weeks later...
Another Update...
ARC Airbox to suit R33 GTS-t. $375 SOLD.
R33 Stock side indicators. $15. / pair... (more than 1 pair available)
Stock Rubber intake Pipe for GTS-t $15. (more than 1 available)
GTR BOV $80.
Some piping for GTR BOV also.
R33 GTS-t BOV $40.
ARC Atmo BOV $100.
Blitz Atmo BOV on Cooler Pipe to suit R33 GTS-t / R34 GTT $120.
R33 Crossover J pipe $20. (more than 1 available)
Stock R33 GTS-t Dump $20.
R33 Stock Radiator (slight leak from Top Tank) $50.
R33 Coupe Series 2 Wing (White) $100.
R33 4door Wing (Silver) $100.
R33 GTS-t Airbox and Snorkel $100.
R33 RB25 Stock Timing Belt Cover $30.
R33 GTS-t RB25DET Rocker Covers $100 pair SOLD.
R33 GTS-t Stock ECU Series 2... $100.
Series 1 ECU SOLD.
KA24DE Fuel rail with injectors $50.
RB30 AFM $50.
RB30 AAC Valve $50.
Pics on request. Prices are O.N.O.
PM me is best...
  • 3 weeks later...
Yet another Update...
GTR BOV $80.
R33 GTS-t BOV $40.
ARC Atmo BOV $100.
Series 1 ECU SOLD.
RB30 AFM $50.
RB30 AAC Valve $50.
R31 Lower / Firmer Front Springs $30 pair.
R31 Wagon Rear Stock Springs $30 pair.
PM me is best...
***FREE POSTAGE For the Month of April.*** ;)
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
Updated Again. :rolleyes:
GTR BOV $80.
R33 GTS-t BOV $40.
ARC Atmo BOV $100.
R33 RB25 Stock Timing Belt Cover $30. SOLD.
Series 1 ECU SOLD.
RB30 AFM $50.
RB30 AAC Valve $50.
R31 Lower / Firmer Front Springs $30 pair. SOLD.
R31 Wagon Rear Hard Springs $30 pair. SOLD.
**More will be added in time... and there is more!
PM me is best...
My 4door R33 is now For Sales too. ---> CLICK HERE.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
