Looking at cleaning up my LMGT4s by getting the rash off them, some of the "Nismo" decals are also starting to peel off so I think its time to replace those as well
my question is can, and where can I buy the decals in Genuine form in Australia, ive found some overseas in America
As you can see here,
the RHD decals are actually an "O" instead of a solid red dot like mine does here
Im hoping to find genuine decals with the solid "O" in Australia
cheers in advance
https://www.sau.com.au/forums/topic/436513-where-to-buy-nismo-lmgt4-decals/
I've PM'd a guy on a different forum who manufactures stickers > estimated cost.
Mitchee here on SAU can probably make stickers too - here in Ryde
Stickers are a different dimension setup depending on whether they're for a 19" rim or an 18" rim > might be best to use a tailor's measuring tape for measurements.
I think Import monster can get them done, he got some for mine.
I also have a contact in the states that made me cutom yellow TE37SL stickers for $60 (rays direct charge about $150 or more i think), Not sure if they make the nismo sticker but i can forward details if you want to enquire about it?
SAU.NSW will be posting up on NYD, our summer 2014 Tech Arvo!
It's all about wheel repairs & it'll be held in Botany.
For Members only - stay tuned :)
Craved Coatings can also fix up your problem Nick if it's just colour matching you need.
He's also here on SAU known as "Craved"
Wow didn't expect so many replies haha
I have no idea how they are going to go abouts cleaning up the rim and keeping the same colour nick... I haven't spoken to the guy about it yet, I just know I want them fixed up
Anthony I actually just spoke to someone one over in the states and the price you quoted is about the same as theirs plus delivery.
Ill shoot you a FYA a message first Terry and ill get back to you if I decide to get them done by Mitchee
Cheer lads
how do you prep the surface of the rim for painting without scarring the paint already there that the painted on stencil wont cover????
nope dont do that, itll flake off and without clear over it, itll be easily damaged through washing even...
vinyl cut for sure, just like they do from the factory...
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
