Hi guys,
I've got some stuff thats been sitting in my garage which I'm hoping to get rid of.
1. Stock 2004 Honda Accord Euro wheels. They are 16" but I'm unsure of the offset or width. I'd guesstimate around 16 x 6.5 + 45. They use the same 5x114.3 bolt pattern and same hub diameter as Nissan, so they could bolt up to a Skyline or Silvia for cheap skid wheels or if you need to pass a defect. They are in good condition, one has a small gutter rash but nothing serious. 2 dont have any tires and the other 2 have really worn out tires. I'm after $250 O.N.O. for these.
post-39984-0-35593600-1387769284_thumb.jpgpost-39984-0-89612000-1387769287_thumb.jpgpost-39984-0-15850100-1387769291_thumb.jpgpost-39984-0-02211900-1387769295_thumb.jpgpost-39984-0-53045900-1387769298_thumb.jpgpost-39984-0-83462900-1387769303_thumb.jpgpost-39984-0-38037900-1387769306_thumb.jpg
2. A whole bunch of Earls and Speedflow fittings. All work fine but some are a bit scratched from spanners.
2 x brand new Earls -10 Straight fittings. One is still in the bag, the other one is taken out but never used
1 x barely used Earls -10 Straight fitting. I think i've tested it once, but didn't fit on my setup so I never used it. Its just got a few light scratches from the spanner.
1 x used 90 degree Speedflow -10 Fitting. It's been used on my old oil cooler setup, but then I changed from a sandwich plate to one with a thermostat so this fitting no longer fitted in.
3 x pretty used Earls -10 Straight fittings. These have a fair bit of spanner markings on them. Again, they are all from my old oil cooler setups. They all work fine, just don't look that great.
My camera kinda brings out every detail in the photos, but they dont look THAT bad in real life.
After $50 FIRM for these.
post-39984-0-34695300-1387769311_thumb.jpgpost-39984-0-02163900-1387769322_thumb.jpgpost-39984-0-62190200-1387769324_thumb.jpgpost-39984-0-29098100-1387769327_thumb.jpgpost-39984-0-82139800-1387769332_thumb.jpgpost-39984-0-75212000-1387769335_thumb.jpgpost-39984-0-47335200-1387769338_thumb.jpgpost-39984-0-34504400-1387769389_thumb.jpgpost-39984-0-78817600-1387769453_thumb.jpgpost-39984-0-95303900-1387769455_thumb.jpgpost-39984-0-74223800-1387769457_thumb.jpg
3. Stock S15 intercooler. I've always kept it in case of defects, but I've since sold my S15 and have no need for it. It comes with all brackets and all of the intake piping up to the intake manifold. I'm after $150 O.N.O. for this.
post-39984-0-02591200-1387769359_thumb.jpgpost-39984-0-21758700-1387769364_thumb.jpgpost-39984-0-66430500-1387769368_thumb.jpgpost-39984-0-83846100-1387769372_thumb.jpgpost-39984-0-90578900-1387769378_thumb.jpg
4. Stock S15 Fuel Pump. It came out of a JDM manual turbo S15 which had about 80,000kms on the clock. It was working perfectly fine, only reason I took it out is so I can upgrade to a bigger pump. I'm after $60 O.N.O. for this.
5. Stock S15 boost gauge sensor. Just the sensor, I don't have the gauge. $10 FIRM for this.
post-39984-0-12306900-1387769381_thumb.jpgpost-39984-0-61173300-1387769383_thumb.jpgpost-39984-0-37467700-1387769386_thumb.jpg
I'm located in Upper Coomera on the Gold Coast, QLD and I'm happy to ship at the buyers expense.
Cheers.
Edited by Goosy
  • 4 weeks later...
  • 3 months later...
  • 3 weeks later...
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
