For Sale:
Year: 1996
Model: R33 GTR
KM : 145,000km (owned since 125'000km)
Link to my for sale thread is here in Qld section.
http://www.skylinesaustralia.com/forums/topic/435008-r33-gtr-1996-for-sale/
More pics are available.
Tasteful mods.
Owned the car since 09' Has had all 100k service done when i purchased the car and regularly serviced every 4-5K with new filters and oil. and all mods have been done since ive owned the car including new turbos Garrett 2860-7's (N1's), tomei expreme dumps, Vipec ecu, Full Stereo, HSD coilovers, Ikeya Formula Camber arms, Incar floor Brace, HKS IC piping kit (not yet installed) Full exhaust from turbo's back custom front pipe, High flow Cat, 5-Zigen 3" with titanium tip on cannon, fresh painted mirrors and front lip, Interior is immaculate and RWC Supplied.
Probably a few other things i have forgotten.
$21'000 ono - No Swaps
This car is clean and original, i have looked after this car for the past 4 years.
If you have any further questions
Car Located: Brisbane Qld
Contact me on
0402777151
Cheers
Darren
https://www.sau.com.au/forums/topic/436712-r33-gt-r-1996-bn6-deep-marine-blue/
Bump
Still up for grabs serious offer will be considered. and inspection welcome upon request.
more pictures in my album.
http://www.skylinesaustralia.com/forums/gallery/album/5575-for-sale-1996-r33-gtr/
Edited by 85URK
  • 1 month later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
