This is surplus to my needs, the delivery of my Avalon unit was actually much earlier than thought
The BFL unit literally arrived yesterday, BRAND NEW! Works perfectly
A solid 30Gh/s of power - Simple to use, plug 'n' play with your mining software of choice
$1100 delivered or best offer!!!!
The quick version - You get rewarded in BTC for supplying the network with CPU power to confirm the monetary exchanges and transactions. The more power you can supply, the bigger the reward.
The BTC you earn, you have transferred to a monetary exchange in Australia that will credit your bank account in dollars, I use www.coinjar.com and withdraw the cash daily, current exchange rate is ~$1000 per BTC
It's a little speculative investment and lots of fun!
What's the payback like?
How long to earn a whole bitcoin?
How much electricity does it use per bitcoin?
EDIT: Actually, if you had one in your house today, it may pay itself off in a few weeks but in 24 months the cost of the power used to mine would be greater than the BC you get in return, so there's money to be made on one for the next couple of years.
Edited by Cowboy1600
What's the best price you'll do on the 50, taking into account it's old tech and you can get a 2x25s for ~$1600 brand new from Butterfly labs - they are ready to ship.
$1600 brand new from Butterfly labs - they are ready to ship......
Check out their shipping costs ;) Then add import duty, GST and the fact that "ready to ship" means........."ready to get the parts off the shelf and build you a bitcoin miner as we don't actually hold stock and make to order"
Dealing with BFL and ordering means you actually get your order 1+ months later
Not being funny at all, but they are very strange in the way they operate.....I can 1000% promise ANYONE that I'd have a brand new 200Gh/s miner in their hands in 2 weeks, BFL can't
I'll do $2000 flat, delivered for the 50Gh/s unit, which should be at least 55Gh/s going by most of the averages I'm seeing from these.
Edited by 666DAN
There wouldn't be any duties, etc, cause I'd get one and I'd get a mate to get one ;) that brings em in at under a gorilla each :)
But $2k ain't bad. I have a little co-op together and I think we're keen. We can't figure out if it'll ever pay itself off or not, but for $500 each we're willing to give it a bash.
I'll be in touch.
BOTH SOLD!
I can get a brand spanking new ASIC 200GH/s Avalon for $4500 if anyone is keen, limit of TWO at this price and only available for the next few days. They land in under two weeks and don't have an owner. Check ebay, second hand ones start at $4000 and go for way more!
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
