Carbon/fibreglass Parts For Nissan R & S Series, Euro Cars, Evo's - Round 3 Group Buy!
Thanks Longz, I am back now.
Sorry for the late reply guys as. I had limited internet access but they have not been delivered yet.
Tracking shows it arrived into Australia last week but no further update so I am chasing this up with AusPost now.
Will update you guys shortly.
Sorry for the delays.
These were beyond my control.
everything arrived in perfect condition except 1 item,
i will pm that person and see if they would be happy with discount or refund of their deposit.
PM's coming shortly guys.
feel free to find your own couriers if it is cheaper, at the end of the day, we all want to save :)
Hi guys
i have left over items from group buy if anyone is interested
R33 GTR exhaust shield $50
R34 GTR exhaust shield $50
RB26DETT coil plug cover (1 tiny crack near screw hole hence cheap price) $70
EVO4-9 coil plug cover $90
EVO 8 radiator cooling panel $130
PM me if interested.
had another member back out so have an R33 Top Secret Style rear diffuser in fibrelgass
3 piece with metal fitting brackets, looks like below (from cartel Aus)but in white gelcoat/fibreglass. $350
R32 stuff
*R32 GTR OEM front grill
*R32 GTR bonnet lip
*R32 GTR/GTST eye lids
Cost on these? Also, are you able to get smoked indicators, replica GTR front & 4 Door VT Style Rear Bumper? Trying to mod on a budget :) If replicas are available of the above 3 parts, I'm interested in those too.
Let me know if possible!!
Cheers man, appreciate the work gone into this thread/group buy.
have left over
R34 GTR JUN style high wing stands
R34 GTR wing blade
R34 GTR front bumper canards (2 pc /side)
R34 GTR carbon exhaust shroud
http://www.skylinesaustralia.com/forums/topic/443761-carbon-parts-for-r33r34evo-left-over-from-gb/
  • 4 weeks later...
closing this thread.
thanks to everyone who participated in this group buy.
There may be another one coming soon as requested by a few members
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
