I'd like it, but from the graph it looks like it will be too laggy for my car on the street :D Dean, was your 33 standard capacity? when did it start to make usable boost?
Cheers
man its a T51R, when that baby hits boost the street becomes a blur
Guest two.06l
bumping again, due to another time waster!
i hope to fcuken god you are not reffering to us with this comment deano.We had every intention of taking this kit off your hands but as it was not the ball bearing cored turbo we were looking for, then it was not suitable for our application.When selling products(you should know as this is the business you are in)you have to be prepared for the reality that people sometimes change their minds.Good luck with the sale.Paul...DIRTgarage.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
