Happy Laps - Queensland Raceway 22-03-14
So I began installing my new front sway bar an hour ago and one of the bolts is rusted shut so I can't get the old one off. Going to have to put it back together. I feel like crying.
Wow, you must have some serious rust under there.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
