OS Giken Internalled Manual Gearbox, Front housing From GTR AWD box. Rear From RB25
Repressed and Fitted with all new syncros Clips Bearings Shifting forks etc, Done by diff and gearbox.
These are the gears: http://www.ebay.com.au/itm/OS-Giken-Close-1-5Gear-NISSAN-RB26DETT-R32-33-34-GTR-input-shaft-/180968934826
This box is worth over $5500.
Located in Brisbane. Comes Complete. 0434575801 Make me an offer or come view.
This is an unused box since assembly. No time wasters. Seeking Genuine interest.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
