Here is a pair of Brand New Turbo for GTR34
M-Spec directly purchase from Japan years ago I was going to install them onto my GTR but no time to do it and now car sold so need to get them going. They are -7 turbos can hold up to 320kw on pump fuel and 350-365kw on e85.
Both turbo are in Brand New Condition. Paid over $2000 plus freight for them my list is you gain
Prefer local pick up but happy to send interstate just send me your post code so I can get the the postage that cost you.
Items locates at CBD Brisbane
Looking around $1200 but nego
My number is 0469347472
Please amend info. Turbos are stock R34 GTR spec ball bearing ceramics.
Tag number confirms that, as well as photos of housing sizes etc.
Cheers.
I think I sold mine for 2-400, can't remember.
Ceramic turbines wheels only last for so long. Those look in good nick though.
They are brand new never onto engine
Yours will do over 100,000km with up to 1 bar boost as they are new then :), 34 last and best of the ceramics.
They are worth storing.
So these have ceramic wheels? Mine where already on the car when I brought it, was told they were n1s which I didn't really care about. As previous owner obviously didn't know either, I just wanted a gtr. But I look up the AA300 number on Garrett and found they were only standard 34 gtr turbos. But running 300kwatw and no probs yet. Glws
And there's no way there new, obvious wear signs. Newish I'd change that too
How about we side bet $2000 I send those turbos to Nissan Australia ask them to inspect the turbo's condition so we will know they are new or been use!!
So you've been diddled by a Japanese scammer?
I think so I still got there commerical invoice when I import the turbos I use the invoice to pay import duty
But I got no GTR now SOLD it my wife doesn't want it, that's why I got my C63 AMG but I like NIssan so I bought a E51 Elgrand Highway Star
Nah I could just buy them off you for less than that. But yeah send them to nissan if you feel the need, there made by garret, so best to try them first I think.
Cool :whistling::whistling: :whistling:
Yep thought the same, when I seen this add, trying to pass these off as something there not, without even searching to find out what they are, and asking 3 x what there worth. Try gumtree might a nissan employee there interested in them
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
