Hi guys,
These parts are off my GTR, all parts have done about 3000km as the car was hardly driven:
Vipec V44 ECU - $1000
Sard 700cc injectors - $500
HKS dump pipes - $350
HKS metal gaskets (exhaust manifold, turbo intake and turbo outlet) - $100
Crank angle sensor - $150
I am based in Sydney and can post interstate :)
Forgot to mention that the vipec has a tune on it by ESP Racing in the ACT, it was running GTRS's with 700cc injectors and made 390kw @ 19psi
Man look? I haven't heard that expression before haha
Really? Well there you go lol
Ubran Dictionary states :
man look
when men (or someone else) look for something but can not find it because they do not look properly. Often whatever they are looking for is right in front of them.
you can't find it because you did a man look
That is gold. I'll add that to my vocabulary going forward.
That deserves a discount on the vipec!
Ive already got a Vipec, Im trying to convince my mate to upgrade from his prehistoric Power FC lol
Yeah I've had 2 power fc's back in the day and a lot has changed since then, even carbies were good back in the day as well
Gotta luv the glitch u get every 15min
Hi guys,
I had a buyer for the vipec do some investigation which we can all benefit from...this ecu suits all skylines from r31 thru to r34 across rb25, rb26, Gtst, gtt and GTR. However, it does not suit the r34GTR as the wiring for the CAS is apparently different.
I can also say that this is better than a v44 (i.e. 4 injector drives and 4 ignition drives) as it has a v88 top board which includes knock protection + it has 6 injector drives and 6 ignition drives. This again is thanks to another sau member who is a tuner :)
    • Physically, you'd expect it to turn the motor 11/8ths faster than a standard one, but I'm not sure of specifics
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
