Hey guys, recently and finally departed with my beloved 33 after 7 years and had to strip it back before sale...
everything perfect working order and all bits included to bolt to stock manifolds or top mount and guarenteed to put a smile on face :D
Kando tdo6sl2 turbo and Tial MVR 44mm Wastegate
Comes with modified or standard rear housing..with modified housing the wastegate sits on top and will bolt to your stock manifold, looks real neat too...or if you are planning to top mount I can provide a stock turbine housing instead...less than 5000kms on it..made 265kw @ 1 bar on fuel capable of more, But I tuned for E85 where it made 303kws @ 17.5.. I think we hit a restriction after that, I didn't bother try find it as it was plenty fast enough for me....very quick, responsive and powerful setup
Comes with dump that bolts directly to 33 front pipe, spacer plates gaskets and all the oil, water lines, and fittings needed...
1900152_10152280105571499_1745701579_n_z
Adaptronic Select plug in
dont waste your time with silly afms or boost controllers , This ECu does the lot...boost control, onboard MAP, launch control, flex fuel, etc etc
Just plug in and play...comes with lines and even a few tunes to get you running if you buy the turbo injectors package deal..
1957985_10152280130731499_717331614_n_zp
750cc Xspurt Injectors rail and SX reg
Custom made to fit under a standard rb25 intake plenum,,these injectors work great with good economy and effiency..
pics here
http://www.skylinesaustralia.com/forums/topic/403711-top-feed-rail-in-r33-with-stock-plenumyes-it-can-be-done/?hl=%2Btop+%2Bfeed+%2Brb25
So there it is, take it all, bolt it on and you're ready to rumble.. Asking $2800 for the lot..prefer to sell as package, but willing seperate if it doesn't.
PM or 0415 121 985
Cheers..
David
  • 3 weeks later...
Ok Ecu is gone...taking offers on Turbo and gate...
Also have set of 6 Splitfire coilpacks I forgot to advertise...work perfect...gotta be worth, I dunno 350$
Turbo with stock rear housing 600$
or
With modified rear housing and gate 1000$
either way it will come with dump pipes, oil and water lines, fittings for block and spacer for manifold..so is ready to bolt up to any rb20/25...
splitfire Coilpacks 350$
Injectors I'm probably keeping them now for my JZ..but for $800 will sell the lot cause the rail is useless to me now...
Cheers.. :)
  • Like 1
  • 1 month later...
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
