R33 Series 2 GTST Sedan
Located in Brisbane QLD 4073
Recent service including gear box oil change (royal purple) and 2 brand new rear tyres.
Handling (upgrades fitted by Option 1 garage and WSM)
Rack Bushes
Rear Traction arms
Rear camber arms
Pineapple Bushes
Front and rear Whiteline adjustable sway bars and poly bushes
BC Adjustable coilovers
Bycas (Hicas elimination kit, replaces arms and joints)
Steering Column spacer
Nissan 350z 18inch wheels with staggered tyres 245 rear 225 front in good condition.
Rear guards been rolled by Fat Fitment
Motor/Gearbox
New Garrett GTX 2867R Turbo with braided lines, new hoses and gaskets (spools up faster than stock, fitted Feb 2013!)
Z32 AFm
K&N Pod filter
Front mount IC
Split dump and 3inch turbo back exhaust with highflow cat
550 Tomei injectors
Bosh fuel pump
Nistune ECU
Quick shift
NPC heavy duty 450hp rated clutch
Apexi AVCR (turned off as running 14lb actuator boost)
All below completed in May 2012
Cometic head gasket
ARP headstuds
Timing Belt
Fan belt
Power steering Pump and belt
Alternator Belt
Interior
Excellent condition
GTR front seats (no rips!!)
Clarion speakers, Pioneer Head unit, BluTooth, Ipod etc......
New leather gear and handbrake boots.
Exterior
Excellent condition!!!! No rust, paint in amazing condition for a 1996 car!!!!
Had factory skirts and rear pods fitted at christmas along with a Viva Garage front lip.
Car is in excellent/immaculate condition, stack of receipts and service history, approximately $Lots spent on the car since March 2011. Previous owner was a married mum of two with mechanic husband!!!! I havent seen a better one at the shows I attend and often get compliments from other club members and enthusiasts.
Aircon works amazingly, handy in this weather!!!!
Am selling as my family has expanded and I cant get all the baby crap in the boot!!!!!
No low ballers, not in a hurry to sell as have a second car.
Rego until August 2014
Road worthy
$11500
https://www.sau.com.au/forums/topic/440134-r33-sedan-immaculate/
  • 1 month later...
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
