Hello all,
I have just imported a Nissan Cube. My priorities have changed and need money for house now. It is just having compliance finished off this week I have been told by the workshop. Car will be sold with registration. This is the first 1.5l to be complianced in Vic and is one of only a few 1.5l cubes in Vic (none on carsales atm). The 1.5l is said to be more efficient with fuel, has more power and sits at a much lower rev while cruising on the highway. Would make a really fun daily while the GTR sits in the garage for the weekend.
The car looks like new and I had to raise my bid at auction significantly to get a quality car. The series 2 gets a bunch of updates including white dials, different grill, headlights, rear tails, etc.
2006 Nissan Cube cubic 7 seater
Series 2, 1.5l cvt
Black
4B Auction Grade - paid top dollar, auction sheet for proof
45,000km with dereg certificate and service history for proof
Excellent condition in and out (looks new on inside)
Smart key - dont need to use key to start
Full electrics
Dark interior
Auto headlights
Leather steering wheel
Foglights
$13,500 Neg
Phone pics, will upload better later,
1604874_10152532577567571_192927570_n.jp
1521814_10152532577837571_1418251489_n.j
1520663_10152532577952571_2138071548_n.j
Hubcaps are in the car. But would look pretty nice with some mesh rims instead :twisted:
Edited by BigWillieStyles
  • 1 month later...
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
