Aftermarket parts galore
Tomei sump baffle $180
Nismo fuel reg $100
Denso 740cc injectors rb26 direct fit $400
Splitfire coilpacks $340
Manley rods h beam used rb26 $350
Mahle forged pistons 86.5 rb26 $450
Apexi avcr black edition comes with manuals etc complete $350
Xforce stainless dump pipes for rb26 with O2 sensors $170
N1 turbo steel wheel rebuild kit for standard r32 r33 Gtr turbos $150
Rb26 stainless front pipe $150
Apexi turbo timer $30
Greddy turbo timer $30
Blitz turbo timer $20
Hks turbo timer $20
Turbosmart boost controller solenoid $30
Splitfire gauges $30
Autometer exhaust temp gauge and sender $50
Auto meter boost gauge 60mm $30
Hid kit removed from r33 gtst $20
Tein Coilovers spanners $50
Apexi boost gauge $40
Drift boost gauge $30
Yellow earthing kit $20
Rb26 hks fuel rail missing hks badge $50
R33 Gtr genuine strut brace front and rear $70 each
Nardi boss kit $50
Turbosmart supersonic bov $50
Gold Coast
0487924497
post-50709-0-88238400-1395190413_thumb.jpgpost-50709-0-96192400-1395190469_thumb.jpgpost-50709-0-47409900-1395190514_thumb.jpgpost-50709-0-87379800-1395190586_thumb.jpg
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
