Rev-Shift Timer BRAND NEW
Keep your engine Cool and Calm.
REV-Shift Timer does it all for you.
The REV Shift Timer was developed specifically to combat improper engine oil cooling and over-revving. The RST is a full functioning turbo timer with an integrated shift light, plus additional monitoring functions. All these features are built into the same compact size unit as ARK Design's Advanced Boost Controller (ABC) so the REV Shift Timer and ABC perfectly complement each other in any vehicle's interior.
Battery Voltage Display
Battery voltage can be displayed on the
LED display, along with battery change
status
Red LED screen
Rev-Shift Function
The engine's speed (RPM) can be captured through either the alternator pulse or directly from the ECU. The shift light can be set to turn on and off at any RPM. For indicator purposes, the LED will flash in bright white when the user preset shift point is reached.
Timer Function
Auto Mode calculates (by driving style) how long a turbocharged vehicle's engine should run after the ignition has been shut off. Manual mode allows the driver to set the desired idle time manually.
A/F Ratio Display
A/F ratio can be displayed numerically on the LED display and in color ranges by the LED indicator. A/F ratio is calculated from the factory O2 sensor. Because most OEM O2 sensors are designed for emissions, the RST readings may vary compared to a wide-band A/F meter.
* A/F ratio readings will only work with Zirconia type O2 sensors.
Keep your eye on the prize, not your gauge.
Over-revving any engine can lead to disastrous results, but with a turbocharged engine the risk is even greater due to the additional air being forced into the combustion chamber. The integrated shift light in ARK Design's RST allows driver to know precisely when to shift to avoid over-revving. The RST's shift light is a bright white LED that can't be missed when in a driver's line of sight. The A/F ratio is displayed in a numerical value on the LCD, and also as different colors on the LED indicator.
on eBay for $130 selling for $60 BRAND NEW - INCLUDING EXPRESS POSTAGE
For Subaru Liberty Legacy B4 BH
Edited by tripsteady
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
