Guest two.06l
Ummm, i accidently snapped one of the wheel studs after changing my brake pads, is it safe to drive around in temporarily (with the remaining 4 studs), untill i get it fixed???
think about it this way 1/5 of the studs is 2/5 more dangerous, drive it with a 3/5 less throttle in 4/5 of a week to get it fixed before your car becomes 5/5 of the scenery.
https://www.sau.com.au/forums/topic/44081-idiot/#findComment-900767
well, i guess it could depend on the condition of the other 4. I did the same thing once and i actually got pulled over and got a defect for it (amongst others) albeit it was a canary yellow V8 commodore which stood out like dogs balls haha Safety-wise, its probably not the best idea as the wheel could potentially fall off (worse case scenario) but if you are desperate like i was, you can as long as you dont do anything stupid. Best advice is to get it fixed asap.
https://www.sau.com.au/forums/topic/44081-idiot/#findComment-900773
yeah i got mine welded on....but it snapped off again later. I must be too strong haha make sure if you get new ones they are the right length....cos my one ended up being longer than the others and the nut didnt fit. Luckily i had 50million of the buggers lying around. Its no big drama and it shouldnt cost you much. If you just twisted it off the hub thingy, you can reuse your original bolt.
https://www.sau.com.au/forums/topic/44081-idiot/#findComment-900801
one less won't kill you..
my other car i found out only had 3 studs on each wheel (and it only had 4 to start with).. and i've been driving like that since i got it for around 15,000km with no probs. If the others are done tightly i don't think the wheel is going to fall off.
But yeah, get it fixed if possible :D
https://www.sau.com.au/forums/topic/44081-idiot/#findComment-901429
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
