Hi folks,
Finally took the cef for a spin after 4 months of being on jack stands and noticed the passenger front brake line leaking.
I'm going to purchase some braided lines for it but wondering if there is a difference between Nissan models. I've got R33 front calipers with what I assume is the standard hard lines.
Any recommendations about which kit to get?
Thanks.
http://www.prospeedracing.com.au/categories/Braking/Brake-Lines-%28ADR-Approved%29/HEL-Performance-%28ADR-Approved%29/
https://www.sau.com.au/forums/topic/440940-braided-brake-lines/
Take a pic of your brake line and I'll tell you what it's off.
When using 33 calipers, dudes roll one of two ways, some will shorten the banjo bolt so it will fit into the caliper properly, others will remove the olive fitting inside the brake caliper, that way the stock banjo bolt will fit all the way in and seal.
You could use R33 lines and not have to modify anything, only problem is that the line won't mount onto the caliper like S13/A31 lines do (they use a clip that slides in, R3x lines bolt in)
Those are R32/R33 Skyline brake lines.
For the fronts, standard S13 lines will work as long as you remove that little fitting down in the thread on the calipers.
S13 lines don't have that box thing half way, it's one line from hard line to caliper with just a slot on the middle for the clip to clamp it into that mount in your pic.
Rear brake lines all same same.
Edited by Nic_A31
Awesome, thanks mate!
I found out HEL do an S13 kit for R33 calipers too. Which one do you reckon I should get?
Same price so I'm thinking the S13/R33 one might be easier to put in.....
S13 kit for R33 front and rear calipers
OR
Standard S13 kit
Edited by konect
  • 1 month later...
Way to slow, but I've been running that HEL S13 -> R33 kit with a set of R33 GTSt calipers for the last 5 years, haven't had a problem with them.
Obtaining replacement discs... that's a different story!
Edited by Lum
Finally got around to fitting these (still haven't bled them - #jackstandlyf) and went together ok but there is a lot of thread outside the caliper.
I spoke with HEL and the said it will be fine as it only needs a few threads to fit in there. Apparently they use the same fitting for multiple vehicles so just use a really long one.
* Random comment - I put "my g o d" in this post and it changes it to "my rajab" how odd!
Edited by konect
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
