HKS GT-RS turbo for sale in excellent condition to suit the RB25DET
HKS part no. 11004-AN008
This turbo is a straight bolt-on item (T3) although oil and water lines will need to be replaced (not included - $100 for braided lines on Ebay).
This is a very responsive turbo and arguably one of the best turbo's available for the RB25DET.
The turbo is in excellent condition and you cannot buy the HKS GT-RS new any longer!
I purchased it brand new from Japan and it's only done <2000km's before being upgraded (to a GT3076R)
It was pumping out 246rwkw@19psi on my car and it pulled like a freight train!
It comes with everything (from the original kit) in the photo's below (plus copper washers for the lines)
Located in SE Melbourne will ship at buyers expense.
$1350
PM or txt me on 0402213701
  • 1 month later...
Yes the turbo is specifically made for the RB25DET and bolts up to skyline dump pipe.
Only oil and water lines would need to be purchased ($100 ebay)
Better make me a good offer as this is kind of sold pending payment.
I've been farked around on here before holding stuff for people.
First with the cash gets the turbo.
i can't make an offer right now it would be a few weeks till i can afford it and i don't want to be another farkaround, can you post on here if someone does cough up the cash for it so i know if its sold?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
