Ok starting to clear out the garage of all the bits and pieces I've collected over the years.
Getting my car ready to sell and have new business venture and baby on the way, so will be getting rid of everything so more coming in next few weeks as time allows.
N1 CRANKSHAFT : $400
Great Condition. Was going to be used for another project but got to go.
Pick up or can organise delivery Oz wide at buyers expense. E-go would be very cheap.
R34 GTR RIMS : $900
Standard R34 GTR rims In good condition but 1 rim has a few scrapes but would make good track rims or easily repaired for set of good rims.
Pick up or delivery Oz wide at buyers expense.
ENKEI RP05 RIMS : $2900
I doubt there is another set of these in Oz. Bought these in Japan for my car and have very little use and are in excellent condition.
These are the Silver type. Pretty sure they are 18x9Jx 25 as I ran these with spacers but I'll check and confirm.
On my Car in Japan
All prices slightly negotiable and I'll get pics pf other parts up asap.
Rims are located on the Gold Coast.
Pics will be sent to guys who have contacted me.
I'll load up pics here later today/tonight.
Delivery to SA around $50-$60 max.
:whistling:
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
