Hi lads,
I bought these pumps brand new from the USA about 12 months ago, never been used. Removed from packaging then put back in and stayed boxed up since then. These are not big enough for the revised build spec. hence the reason for sale.
This is a 1000hp setup as put together by a senior tech at Weldon with the 1100-A as a lift pump feeding a surge tank then the D2015-A as the high pressure pump to the rail.
http://www.weldonracing.com/product/64/1100-A_Flow_Through_Fuel_Pump.html
http://www.weldonracing.com/product/10-6/D2015-A_%28-8_inlet___outlet%29.html
Ideally they should be sold together for someone looking to upgrde their fuel system and never have to work about it even again. And if they ever do kak themselves, you can rebuild it with a cheap kit purchased from Weldon! Try doing that with a Bosch or Walbro.
I will sell them separately as both can be used individually anyway but I needed two pumps as I was running a surge tank.
D2015-A can be had for $700.00
1100-A can be had for $400.00
Prices are firm, will ship at buyer expense. Just remember, if you bought these new you are paying at least 10% more plus shipping plus GST as the value is over $1000.00.
Thanks all,
Mike
0407801338
Edited by bigmikespec
Still got these bad boys... doesn't anyone want some hardcore fuel pumps capable of flowing 1000hp each that will last a lifetime? Too many cheap Bosch and Walbros around these days, come on lads :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
