Hey guys!
So, I have an RB25 R32 GTST - it's been a pretty solid car, however, it's had a problem with boost creep since I replaced the turbo due to the stock one dying. The turbo I got is an ebay one (save your flaming) and has been good for the last 15,000kms. However, as you can imagine, not being able to top out gears 2 and up is kind of annoying :P Before you ask, the reason I've put up with it for so long is because I know the effort I went through to swap out the turbo and I realllly didn't wanna do it again :P
Now the time has come and I'm sick of not being able to use my car the way it's supposed to! So, to the point, can anyone recommend a place in Sydney who can pull the turbo, port the wastegate and put it all back together? Looking for cheap :P
Any other input is welcome as well.
Cheers!
Josh.
And now the cheap turbo starts costing you more than the Hypergear. Lesson learned. :P
My suggestion, buy some tools and learn for yourself. It's not that hard.
Yeah, but at the time my turbo died I was poor and needed my car on the road, so a dirty eBay unit was the trick! In my defence, it HAS done wwhat I wanted it to do, which was get me back on the road, and in fact, it seems to be a really nice turbo.
Also, to note, I KNOW how to do it, I put the replacement turbo in myself. However, circumstances have changed and I have sweet f**k all tools at my disposal and where I park my car has almost no working space, with cars parked either side. Therefore, doing it myself would be too much of a PITA, not to mention the cost of tools will probably be close to what I'd pay for someone to do it anyway :P
So as much as I appreciate the comments, still looking for someone who knows someone in Sydney to do this for me ;)
Orrrrrrrrrrrrrrr lend me a shed full of tools and a space to work for a day :P Preferably the above option first!
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
