Cleaned out the garage need to sell afew things,
S13 Just jap Adjustable lower control arms, could also fit other modles. $80
R32 GTR front strut brace, also fits gtst $80
R32 GTR nizmo Dash with only 33,000km, $300
R31 Auto tail shaft been rebuilt, $80
R32 Top camber arms with newish red bushes, $50
TURBO t3t4 internal gated ebay spec $80
3inch Cannon came off a r32 $50
Bosh 044 internal pump working on r32 gtst cradle $100
R32 GTR N1 boot lip, rubber $200
R32 GTR seat modified to fit r31rail, has abit of wear usuall spot $150
R32 rear seat belts $50
R32 Front standard sway bar $30
R32 Rear camber arms $30
Rb20 Cam covers have two pairs, one is blue other is stock. $ 50 a pair
R32 GTR 440CC injectors with resistor pack good upgrade for ur RB20. pulled them out as i went back to stock setup $350
Z32 Air flow meter, ebay special $50
Cefiro RB20 Loom $100
Electronic boost gauge$20
R32 skyline plastic trims that run under the door $40
R32 plastic surround behind steering wheel $20
R32 stock boss kit that horn connects to and also hicas plug $40
R32 Gtst castor rod with newish red bushes $50
S13 Throttle cable $50
R32 Lower control arms, good upgrade for R31 same length as s13 $80
Turbo smart BOV $80
R32 gtst Bonnet latch $50
RB20 exhaust manifold $40
Rb20 intake pipes, one with bov other one has been welded behind so u cant see that it had a BOV $50 each
R32 GTR TEIN castor rods, will fit GTR AND GTS4 $150
R32 carbon canister $20
Bucket seat, Rails to fit r32 but only the two front holes line up, rears need alittle fixing $50
All items are in South east Melbourne, can ship smaller items. Just text me and ill send you a photo 0422155233
https://www.sau.com.au/forums/topic/443571-vic-garage-clean-out-r32-parts/
bump,
Also have
R32 silver boot rough needs paint, $20
R32 Black rear bar with reverse lights, $20
R32 taillights black, one hasnt got globes and is a little cracked where the connect but would still work, $40
R32 doors with windows, dirvers side handle missing $40ea
R32 front and rear trims $40 for all
R32 front stock shocks and springs connected to the arm they connect to without the knuckle $40
