whats your thoughts on the unichip in an r33 gts-t auto?
i got a few mods at the moment
catback 3"
stage 2 shift clutch
airpod
FMIC
apexi boost controler old one but works good
series II motor
making 187rwkw
going to put on
fuel pump (prob GTR have a VL standard one is that anygood or chuckable?)
3' dump pipe + front pipe
high flow cat
replace plastic pipe with 3" stainless AFM to turbs
and a unichip last bit
hoping to put out over 200rwkw might push for 250rwkw but then injectors and new turbo are the issue and manifold
but main issue is how are people going with the unichip?
was gonna go the e-manage but no tuners in adelaide except rpm and they only have the program they aren't that good with it ( from what i heard) but there good no probs there
https://www.sau.com.au/forums/topic/44362-unichip/
got two feet for launches its not hard better for it, like weather changes will stuff up the stall converter
pFC doesn't work with autos, emanage are having probs with autos and no tuners so no option there
oil cooler for trans was thinking that, but don't skylines come out stock with em? i have a cooler on the front of the radiator, looks like a stock trans cooler, i could be wrong though
https://www.sau.com.au/forums/topic/44362-unichip/#findComment-906968
You don't put oil in your trannie but yeah, it should have a cooler out front there. Is it between the radiator and the front mount?
I don't know but isn't the cost issue with Unichip the tuning rather than the install? Ie hours and hours of tuning necessary.
https://www.sau.com.au/forums/topic/44362-unichip/#findComment-907032
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
