whats your thoughts on the unichip in an r33 gts-t auto?
i got a few mods at the moment
catback 3"
stage 2 shift clutch
airpod
FMIC
apexi boost controler old one but works good
series II motor
making 187rwkw
going to put on
fuel pump (prob GTR have a VL standard one is that anygood or chuckable?)
3' dump pipe + front pipe
high flow cat
replace plastic pipe with 3" stainless AFM to turbs
and a unichip last bit
hoping to put out over 200rwkw might push for 250rwkw but then injectors and new turbo are the issue and manifold
but main issue is how are people going with the unichip?
was gonna go the e-manage but no tuners in adelaide except rpm and they only have the program they aren't that good with it ( from what i heard) but there good no probs there
https://www.sau.com.au/forums/topic/44362-unichip/
got two feet for launches its not hard better for it, like weather changes will stuff up the stall converter
pFC doesn't work with autos, emanage are having probs with autos and no tuners so no option there
oil cooler for trans was thinking that, but don't skylines come out stock with em? i have a cooler on the front of the radiator, looks like a stock trans cooler, i could be wrong though
https://www.sau.com.au/forums/topic/44362-unichip/#findComment-906968
You don't put oil in your trannie but yeah, it should have a cooler out front there. Is it between the radiator and the front mount?
I don't know but isn't the cost issue with Unichip the tuning rather than the install? Ie hours and hours of tuning necessary.
https://www.sau.com.au/forums/topic/44362-unichip/#findComment-907032
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
