Hi,
I just recently got my car back from its 100,000km service and I noticed that my head unit (Pioneer DEH-7450MP) is doing something that it didn't do before the service:
The screen is an aqua-on-black display (the text is aqua). Every now and then the colours reverse (such that the text is black, and the backcolour is aqua). The head unit seems to work fine, but the random changes in colours flipping is distracting (while driving).
It slipped my mind to take the head unit off when I took the car in for servicing (the battery was disconnected at some stage during the service I'm sure). The service was done by my mechanic (someone I know and trust). I'm sure he took the negative terminal off the battery.
Never-the-less, I want to know if it's some setting I need to fix or is it something more terminal with the head unit?
https://www.sau.com.au/forums/topic/44429-help-pioneer-head-unit-playing-up/
it is probably a setting in the newer versions...just go through a section of the manual...
i know on my mates JVC i can change like 10 diff colours n stuff...
if it aint anywhere to be found, then go to where you bought it from n ask them , they SHOULD know
Thanx for the help dood.
I don't have the manual for this head unit cos it came with the car at purchase. Luckily I found the manual online, tho  :D. Turns out it's some 'reverse' mode and all it does is it reverses the colours every 10 seconds. Bah..
That sounds familiar. I got the shits with my DEH-P6450 when I first got it with the same problem.
    • On 12th June, the mechanic could not figure out what the issue was, but the car seems to be flooding with fuel. He was suspecting the tune, thus referred me to a tuner. Although the tuner is not familiar with Nistune, last Monday (30th June), he came over to try and re-map it. Despite the tuner trying to completely stop fuel, it kept sounding like it was pushing fuel. Tuner ended up suspecting either the ECU or Injectors. I do not believe the ECU or Nistune is the issue, as the Nistune software reads and communicates properly. Today, I removed the (new) injectors to see if they are clogged or leaking. Surprisingly enough, after those 3 days of driving, injectors 2 and 3 look very blocked. You can see the difference in the picture. I blew a bit on 3, that is why it doesn't look as clogged as 2. I am still unsure if this is what is causing the no start issue, but I am now feeling that I may have bought the injectors and Nistune without the need to do so, as the problem seems to be coming from somewhere else.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
