  • Replies 126
haha, i do not condone street racing... this week feels like slightly stuff up and youll be the next one on the front page of the newspaper! Oh well.. Skylines come out in force on saturday night! ill be in town somewhere flag me down!
I was on holidays in QLD hey & didnt hear about this 'skyline crash' down central coast till today, my m8 was telling me about it, pretty messed up.
As for Saturday night.... F#ck driving off, I'll be hitting the pubs & clubs!
https://www.sau.com.au/forums/topic/44473-newcasle/page/3/#findComment-1102587
im in Newy too ppl....the yella terra will be back on the road in oh...about 2 weeks hehehe it will be a real G TT if ya know what i mean hehehe
Bitch you got a RB26 under that sucka! :wassup: lol ! You going Single or Twin turbo?
Could you post up all the mods for you car *scare off fellow newy skyline owners haha*, it looks nice hey... There so arnt any r34's in Newy hey... wish i had one. I've only seen like 3 in Newy, yours, vnom, & some other grey one.
https://www.sau.com.au/forums/topic/44473-newcasle/page/3/#findComment-1106719
I sticking wif da twin set up....mmm saw me nice polished bits yeserday hehehe...yeah just sorting da last few bits and hopefully....hopefully all goes well (no parts delay) and she be back.
Yeah only 2 coupes I seen up here....other than that i seen a cpl of sedans...loads of 33's and 32's in newy tho
https://www.sau.com.au/forums/topic/44473-newcasle/page/3/#findComment-1106740
Guest two.06l
hey guys i'm up for organising a cruise soon. any ideas? around newcastle or maybe central coast or nelson bay could be fun.
Nelson Bay is the go (we live there) Soldiers Point is even better. The Supra club in Sydney came up last weekend. They came out the end of the "point" late in the afternoon for some carpark "fun" without the hassle of authority giving them a hard time. Our drag weapon should be mobile in the next few weeks so let us know. Paul and Stacey...DIRTgarage.
https://www.sau.com.au/forums/topic/44473-newcasle/page/3/#findComment-1110253
I'd be more inclined to go central coast way but whatever, it'll be all good.   I'd just like a date set once we get a few ppl interested!
yeah good call.. well lets see a show of hands if we goto central coast.. i guess lots of central coast ones can join in and some sydney ones...
What does everyone think ??
Sunday 19th good ot not long enough notice?
https://www.sau.com.au/forums/topic/44473-newcasle/page/3/#findComment-1111117
As a Medowie boy, may I second (or third) the motion to go to the central coast instead? I won't be there, but I've ridden the ZXR down the old Pacific a few times, and whilst soldiers point is very scenic, it's snoozer driving. I guess it depends on the purpose of the cruise.
Old Pacific > Nelson Bay Rd! Big time. You can actually drive/ride a decent track, rather than just set the cruise control and go to sleep. It's all sub-speed limit, watch out for motorcyclists cause there are always LOTS on the weekend.
https://www.sau.com.au/forums/topic/44473-newcasle/page/3/#findComment-1112030
