Alright, so to my luck i've picked up an R32 with an R34 NEO motor for 800 bucks and decided to join this forum. See, im a mechanic, and more of a holden man however i have bought this car from drift.
So the issue is at this stage the car will crank for about 20-30 seconds, occasionally fire, and flat out refuses to idle.
engine revs beautifully once started and when its slightly warmed up will idle very very roughly.
Now, i've just put a second hand set of coilpacks because the original 6 littlerally fell apart in my hands.
There was suspicion from the previous owner that the engine has cooked.
Compression test being done tomorrow for my own peace of mind.
All input much appreciated! Here's the engine specs according to receipts and my knowledge.
R32 running R33 RB25block with NEO head + computer.
Possibly running Tomei Type B cams. (260 dur 9.15mm lift)
Full exhaust from manifold back. manifold has small crack near turbo joint.
Hissing noise from engine bay, unable to diagnose at this stage because it was only me and now pitch black outside.
I have knocked a solenoid hose on the hard intake pipe which goes straight into the throttle body (Not attached to pipe, is on a bracket)
Car's running a FMIC with the worst plumbing ive seen on a turbo car.
FROM MY KNOWLEDGE car is tuned to suit all the modifications.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
