Hi,
My HID have started to randomly turn off while driving...I change my right one nearly 2 years a go as it was flickering but lately the left started to switch off, but now suddenly the right would switch off and the left stay on...
Anyone know of a good electrician that has worked with V35 and knows what he's doing in the Sydney area?
  • 10 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
