Last night as i was driving home from work my r33 began to run wierd
First when i pushed the accelerator nothing would happen and it was very temporary and a second later of pushing harder it would be back to normal. This occured a few times and few of those times i shifted to a gear below and it went fine.
Then later it completely gave up and the engine pretty much turned off (lucky i was on the left lane and put hazards on). Restarted the car and again a few times seemed to struggle to accelerate but ended up going and i drove home with a few temporary loss of power.
This morning i drive into work and no issues at all.
Any ideas?
Was thinking coil packs? but no conisistant misfiring etc
Fuel? My exhuast does have a massive hole in the axleback if thats mucking around with AFR?
https://www.sau.com.au/forums/topic/446835-r33-gtst-running-wierd/
your exhaust wont be causing issues with your afr's. Get some CRC contact spray and afm spray. clean your plug and pins for the afm and clean inside the afm with the afm cleaner spray. Give that a shot first before anything
I think similar thing happen to me, it was the o2 sensor, because I bought an aftermarket o2 sensor without plug, so I had to join the wires up and I just taped it, and problems occurred. But it seems to be fine once I've soldered the wires.
So maybe check your o2 sensor?
  • 4 weeks later...
sorry been a while as ive been busy with other things (r33 is barely driven)
Changed the spark plugs over the weekend. Didnt look too bad but prob was best to change them. Coil packs are confirmed to be spitfires and are in good visible condition. Did manage to snap a coilpack clip (still clipped in but will get a new coilpack harness to sort that).
Drove the car after - drove ok for 10 mins, then started spluttering and after a while pretty much lost all power. had to fight with it to and after a while able to run around 2000rpm. Took it back home, but when 2 min before i got home, it started driving normally.
Also the day before i changed the spark plugs i tried starting and it struggled first few times but started after a while.
My belief is fuel (though im barely an expert)
Theres fuel in the tank
Fuel filter was changed at last service (around 1500ks ago)
So if it is fuel my guess is the following
Fuel pump?
Fuel lines?
Fuel tank?
Injectors?
Any idea how to check/test them
or any other ideas on whats causing this?
seems like an intermittent problem, is the earth point from the battery on properly and is the point clean?
is the fuel pump earth hard wired?
if you can get your hands on a fuel pressure tester then having a look at that would be an ace idea. If its spluttering and you have good coils, good plugs n fuel, it may be fuel pump related but its hard to point at that (e-diagnosis)
hows the CAS set? it could be going into Rich n Retard.
Many factors
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
