Last night as i was driving home from work my r33 began to run wierd
First when i pushed the accelerator nothing would happen and it was very temporary and a second later of pushing harder it would be back to normal. This occured a few times and few of those times i shifted to a gear below and it went fine.
Then later it completely gave up and the engine pretty much turned off (lucky i was on the left lane and put hazards on). Restarted the car and again a few times seemed to struggle to accelerate but ended up going and i drove home with a few temporary loss of power.
This morning i drive into work and no issues at all.
Any ideas?
Was thinking coil packs? but no conisistant misfiring etc
Fuel? My exhuast does have a massive hole in the axleback if thats mucking around with AFR?
https://www.sau.com.au/forums/topic/446835-r33-gtst-running-wierd/
your exhaust wont be causing issues with your afr's. Get some CRC contact spray and afm spray. clean your plug and pins for the afm and clean inside the afm with the afm cleaner spray. Give that a shot first before anything
I think similar thing happen to me, it was the o2 sensor, because I bought an aftermarket o2 sensor without plug, so I had to join the wires up and I just taped it, and problems occurred. But it seems to be fine once I've soldered the wires.
So maybe check your o2 sensor?
  • 4 weeks later...
sorry been a while as ive been busy with other things (r33 is barely driven)
Changed the spark plugs over the weekend. Didnt look too bad but prob was best to change them. Coil packs are confirmed to be spitfires and are in good visible condition. Did manage to snap a coilpack clip (still clipped in but will get a new coilpack harness to sort that).
Drove the car after - drove ok for 10 mins, then started spluttering and after a while pretty much lost all power. had to fight with it to and after a while able to run around 2000rpm. Took it back home, but when 2 min before i got home, it started driving normally.
Also the day before i changed the spark plugs i tried starting and it struggled first few times but started after a while.
My belief is fuel (though im barely an expert)
Theres fuel in the tank
Fuel filter was changed at last service (around 1500ks ago)
So if it is fuel my guess is the following
Fuel pump?
Fuel lines?
Fuel tank?
Injectors?
Any idea how to check/test them
or any other ideas on whats causing this?
seems like an intermittent problem, is the earth point from the battery on properly and is the point clean?
is the fuel pump earth hard wired?
if you can get your hands on a fuel pressure tester then having a look at that would be an ace idea. If its spluttering and you have good coils, good plugs n fuel, it may be fuel pump related but its hard to point at that (e-diagnosis)
hows the CAS set? it could be going into Rich n Retard.
Many factors
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
