Stock r34 gtt shocks and springs.
Currently have super low king springs on them (drops the car about 50mm from stock), will also include these for the sale.
$100 pickup only at the moment, Rouse Hill area.
Selling due to upgrade to coilovers. No leaks or knocks, just needs a good clean.
https://www.sau.com.au/forums/topic/447167-r34-gtt-stock-shocks/
  • 3 weeks later...
Hey Jordan, sorry these were sold 10mins after i bumped lol.
BUT one of my mates is also selling the same setup for 200 ono. His price, not mine. Will also come with the stock springs as the buyer of my set didn't want them.
Let me know if you're interested.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
