Hey all
Myself and ska are goin out cruisin with the coast cars bunch tonight.....any GC ppl that want to come meet at yatala bp at 7 then head towards milton maccas then onto harry's (yes harry's) we will probably be there for bout an hour or so then head on cruisin somewhere...destination to be assigned.....we will NOT be parkin at harry's but in the parking lot beside it.....Anyone who wants to come feel free and posts here or Pm myself...or sms me
0401858265.
Yes i know harry's can be a defect spot but i dont want to here it cause i know....its just a nice cruise.
Ben
https://www.sau.com.au/forums/topic/44940-cruise-2nite/
If anyone wants to meet up give me a call...
Ill be on the Gold Coast all nite
My mate has a room at the Bel Air right near casino. So where having a party/cruise
Im heading up soon
Spent 4 hours polishing car yesterday :cheers: So im eager to show off my beauty along with her new bits :)
Catcha
https://www.sau.com.au/forums/topic/44940-cruise-2nite/#findComment-917628
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
