Vs Ute V8 5L
VS ute series 3, 2000model has been modded by previous owner
- Extractors, 3inch exhaust ( classic V8 rumble)
- Diff modified for response
- 18inch wheels
- aftermarket cams
- comp test is 160 on all 8
- electric windows
- needs dash cluster replaced as it stopped working, all front shocks are bit soft, apart from that is a solid engine and drive line, good body
$4700 ONO South Brisbane
0466 257 118
 Share
    • I love Catalunya.  Got a 1:54.632. The AMG is a hoot.
    • I hadn't got that far, my main worry was the connection to the actual calipers themselves. I'm just using new (ish) stock brake lines in the stock setup. I've just had a stud welded to the knuckle that is a little lower than the original stud (so my knuckles have two studs each side) to not have it be stretched so far in previous BBK setups, so the "block" (in the second picture) mounts a little lower for me and I hope I don't need to change anything. I may have even changed the connection to the calipers in the past and have since forgotten I did that. I may not have. Guess how I'm gonna find out. Source: hopium
    • It's more so I'm using the 1x piece line from HEL that goes from the body to the caliper. There's no middle block/mount like the HFM ones or the GKtech ones. There are certain angles/suspension compression where the line actually slightly contacts the ARB. Below of how mine sit (not my photo): How I want it:
    • Oh I have mine all sitting in boxes ready to go, two sets of rotors, four sets of pads and caliper rebuild kits. They send a survey asking me if I had installed them months ago :p Grinder not necessary to fit the fronts, and not *really* for the rears. They have some good simple videos on how-to. I don't understand brake lines but from what I understand... somehow... OEM lines work, even though people say 350Z and 370Z use different banjo bolts, so it's possible 350'z had some different setup that Nissan changed to the 370Z/R33/R34 system? ....though are a little short, but past-me made a new bolt hole to bolt them to to reach my current fronts so I should be okay... maybe. In any case HFM don't sell any *different* line kits for R33/R34 front brakes than they do for the 370Z kits. So in my mind they must be compatible or they would have different products made to suit the different calipers. Please test and confirm for me kthx.
    • @Kinkstaah HFM will have a spicy BF sale in November, might be a good time to load up on the adaptors, new lines, etc. Then may the best grinder win lol.
