So after I got this car not long ago, I realised the roof had been repainted somehow as the quality of paint is shit - upon the first wash about 1 square cm's paint had peeled, then developed to a coin's size. Therefore I decided to give it a wrap since I was planning to change the color anyway. However I made a horrible rookie mistake by not sanding the chip/peeling down before applying the wrap - so after I attempted to move the wrap about to adjust the position, massive peeling happened and the roof now look like disaster.
I took it to a smash repairer and was quoted 600 to repaint the whole roof (which I think was a rip off even though it's tri-layer pearl) and was told that sanding will not make it work, and if the panel is exposed then even if I wrap it with premium vinyl there would still be rust issue. They refused to simply sand/buff it as they did not have time today.
If anyone had dealt with peeling paint before, how safe would it be for myself to sand the peeling edges (upon removal of wraps the rest of the roof seems okay (no peelings) and wrap it again? Will definitely visit Supercheap tomorrow to seek DIY solutions.
Alternatively, if anyone in Sydney knows someone who can deal with this roof and operates on Saturday, please let me know. Much appreciated.
Post back here once you get it fixed and how much you payed, I'm looking at getting mine resprayed soon
Went around for a few quotes but all around that 600 figure. Damn tri-coat pearl.
In the end I decided to manually sand the edges down to the primer and wrap again - actually looks not bad. Won't notice that from two metres away. Only reason for doing this was that I need to make the car look not like shit last Saturday so that I can make it to the SAUNSW cruise on last Sunday.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
