1988 A31 Nissan Cefiro
118XXX KMS on body
288KW on 19PSI
engine:
S1 RB25DET rebuilt by some guy in Traralgon
GReddy T67 25G turbo
GReddy 44MM external wastegate
GReddy high mount exhaust manifold
GReddy forward facing plenum
GReddy dump/front pipe
GReddy water temp sensor
GReddy radiator
GReddy oil cooler
APEXI deltafin intercooler
HKS RB20 camshafts, 264/8.5mm
HKS RB20 cam gears
Tomei oil restrictors in block
Q45 throttle body
ARP head studs
replaced head gasket
Tomei twin feed fuel rail with -6 fittings
1000cc top feed injectors
Gates timing belt
braided wategate vaccuum line
custom twin 3" straight pipes
Splitfire coilpacks
Nismo thermostat
Z32 AFM
Nisstune ECU
Walbro fuel pump
gutted cat
Cusco catch can
RedTop RB20 rocker covers (-10 fittings)
battery relocated to boot
lobster back metal intake pipe (4")
lobster back cooler piping
driveline:
RB25 5speed manual gearbox
custom one peice tailshaft
ORC single plate clutch
KAAZ 2way lsd with 4:11's
brakes:
R32 GTST four piston front calipers
R32 GTST front discs
R32 GTST rear discs
R32 GTST twin piston rear calipers
R32 5 stud rear hubs
S14 5 stud front hubs
HKB 10mm extended rear wheel studs
BM44 brake booster
Cusco BMS
suspension:
Whiteline adjustable rear swaybar (27mm)
SuperPro steering rack bushes
JJR solid steering shaft bush
Nismo rear strut brace
MidnightMods rear subframe risers
Kazama castor arms
Kazama tie rods
Kazama tie rod ends
Driftworks front knuckles
JIC camber arms
JIC FLT-FAS coilovers
Cusco front strut brace
Ultra Racing fender braces
PoweredByMax rear toe arms
interior:
GReddy boost guage
Defi oil temp/pressure and water temp guages in DIN slot
JJR drift handbrake button
Juran seat rail
Bride Brix 1.5 drivers seat
Bride centre console
R33 GTS-T passenger seat
McQueen motorsport weld in half cage (retaining all standard interior)
Cusco bolt in cross bar
Nardi 350mm deepcorn
Nardi boss kit
S14 gearknob
Factory Nissan floormats
Kenwood headunit
JBL front and rear speakers
deleted all a/c related parts
deleted all heater related parts
deleted all sound deadening
fire extinguisher
dash loom and fuse box stripped to run bare essentials
exterior:
Autech body kit
Nissan factory weathersheilds
late model S3 grill
late model S3 tail lights
roof spoiler
pumped guards
wheels and tyres:
front:
17X9 +11 SSR Agle Strusse (not pictured)
rear:
17x9.5 +12 Gramlights 57C (not pictured)
Rays wheel nuts
SSR valve caps
have had this car for 5 years now, current engine set up is very reliable and is pretty much a turn key drift car, dont see why it couldnt be very competitive with a few tweaks
car is currently on historic rego, so will be sold un registered
happy to send interstate at buyers cost
alot of spares will be included in the sale if bought for the right price
any finer details can be discussed with serious buyers, alot more to explain about it but PM me for info
located in Point Cook Victoria
$15,000
10339262_1488784164679855_15320801702149
10469292_1488784218013183_75911823132367
1548095_1488784281346510_233289168494227
1502765_1488784321346506_279259860856935
1531758_1488784484679823_498850283576937
https://www.sau.com.au/forums/topic/451447-vic-1988-a31-cefiro-big-mods-list/
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
