After an adapter for the APEXi Power intake to fit R33 gts25t AFM
or referral to anyone that can supply me with a new one.
willing to pay $50 for secondhand
Email: [email protected]
in Sydney
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
