Had an accident a year and a bit back,
After accident tried to start it, wouldn't even kick so left it.
Took plugs out, dropped a little oil and fuel in, cranked motor till oil pressure came up.
Left plugs out for two days so it would dry.
Plugs back in, wont start or even kick.
Compression is fine, "Start Ya Bastard" makes no difference.
Removed cleaned plugs etc again. They looked wet.
Got ECUtalk up adn running again, ECU reported "no faults".
Everything seems to be working (throtlle sensor/ open/closed, AFM have the same readings, etc)
Reset the ECU, now it says "Error Reading codes".
Any suggestions, I've been stuffing around with this for a week and its doing my head in.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
