Hi R334door' date=' I have re read this thread a couple of times and I see no reference to the A/F ratios. If you have them, can you post the power graph with A/F ratios and boost. The Microtech has air temp correction, which I assume is being used, if so a graph of that will be handly as well. That will help the diagnosis a lot.
[i']Hmmmm.....only have the shootout graph. I'll ask whether Shaun still has that data and is able to extract it from his Dyno Dynamics gizmo.[/i]
What model of Microtech is it? Are you running wasted spark? Have you paired up the injectors (ie; using 3 injector drivers)?
Yoiks......NFI?? It's a Microtech LT12 (like Matt's) but I'll need to quiz Shaun about the rest. Hopefully he'll have the answers.
I have never run a Skyline on anything other than 98 ron, it simply isn't worth it. Since you have a "free fuel" advantage, I would suggest a 20% mix of toluene (I use 10 litres of toluene with 40 litres of fuel). Don't get it on your hands or inhale it, it's not nice. One tank full and $50 on the dyno with the items above logged will eliminate many things.
Yes.....good ole Toluene!! Had alot of fun with this stuff in the good old days, building up a mates 1340cc Mini which ran a CR of 13.0:1!! It's a interesting thought and I'll look into it a bit more. As I'm stuck with this Caltex Card for the time being it may be the practical alternative for my second tuning map.
Thanks for the instructions on checking out the timing belt Mark, I'll definitely check this out on the weekend. Would love to eliminate it as a possibility but somehow imagined it would be more difficult!
Now I see what you mean Joel. I suppose in a way this is the hardest thing to check as the injectors need to come out and go to someone else for flow testing. I can see the sense in it and I'll definitely get this done but I'll leave it until last and check out the more "user accessible" things first.
Steve, I know what your saying mate, that was my concern also (comparing it to a standard ECU). I have a Microtech LT12 and it was apparently the second unit ever installed and setup by RPM (Lachlan "Freebaggin" I'm told was the first....but don't quote me). It doesn't appear to be a problem at this stage as the results are consistent and aren't varying between fiddlings.
I have the standard ECU but I feel that this would just introduce yet another variable. I'd rather work with what I already have and eliminate one thing after another..........but yeah, it's tempting!!
I wouldn't be suprised if I discovered something like this Ben, but I highly doubt it (couldn't be that lucky). I'll definitely know a bit more once I take some covers off to try out Mark's suggestion.
I believe that my car/I hold the number two spot for an LT12 install. My car and Lachlans were done back to back - sort of like sister cars :D AFAIK.
Howdy Matt,
Whoops!! Sorry if I've got it wrong......as you know I wouldn't have the foggiest idea if it were the case (never had it back then), it's just something that Shaun mentioned when I collected the car last Friday. :Oops:
He said that when he was with RPM, they had a particular naming pattern and the map name in my ECU is "RPM2R33t", so he must have figured it was the second!
:idea: How about I get Shaun to rename the map to "RPM2.5R33t" (just in case "RPM3R33t" is also on this forum)!!
Cheers.......:cheers:
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
