Have decided today that I will part out some parts in the car so the following items are for sale:
Bilstein shocks- Car handled really well with them, great for street cars and occasional track days.
Suits: 4wd Skyline / stagea models with eye mount at the rear. eg GTS4 GT4
Condition: Good condition, No leaks, fronts are only 5000km old, rears are about 15000km with circlip groove machined for height adjustment.
Also Included: Suspension top mount, stock R33 GTR rear springs (slightly higher spring rate than GTST).
Price: $350 for the set
Apexi Power FC for R33 GTS-t with EL Controller- Good reliable cheap plug and play alternative compared to most other ECUs.
Suits: R33 GTST, S1 Stagea with RB25DET
Condition: Only roughly 9 months old, latest model, in almost brand new condition
Also Included: EL hand controller, Box and all instructions included
Price: $990
Top Feed Billet Fuel Rail for R33 GTS-t- Does not require modification to the stock plenum, makes top feed conversion a walk in the park. It is set up as a single entry fuel rail but you also have the freedom of converting it to twin entry if you wish- just undo the top cap
You will only need to get the injectors and some fuel hose if you use this kit for the conversion- will save you a lot of pain and headaches
Suits: Bolt-on fuel rail for R33 RB25 top feed conversion, using 1/2 height top feed Bosch EV14s or Siemens Deka injectors,
Also Inculded: Cap and fitting for the top fuel exit and fittings on both ends, plenum spacers for the rail, spacer for 14mm injectors, 14mm to 11mm injector top hats
Price: $150 - will also throw in a generic fuel pressure reg for free. Been using this on a 280rwkw setup with no issues.
Splitfire Coilpacks- engine runs smooth and strong @ 280rwkw with them
Suits: series 2 R33 GTST RB25 and R34 GTR RB26,
Condition: as new condition, only had them for roughly 5000km as well.
Price: $300
Located in North Sydney, pick up available, shipping @ buyers expense.
PM me if interested.
Edited by chiksluvit
Also stock fuel reg adapter for external mounting, good for top feed conversions without having to buy another reg
Does not come with the fuel regulator
$40
Fuel rail with the spacers and adapters. This makes rb25 side feed to top feed conversions with 1/2 height injectors like bosch ev14 , injector dynamic id1000s or Siemens deka a walk in the park
What it looked like installed
The photos for power fc
This is the latest PFC for ecr33 with EL commander and additional tuning load vs timing feature. The EL hand controller has improved visibility.
Comes with box, original packaging etc, only used for roughly 9 months
Also included as part of the fuel rail:
Injector collar / spacer that sits on the plenum, brand new O rings will also come with them too as pictured in previous post
One thing I'd like to add:
I have been very reasonable with the price of items that I have listed- a few of them being half or less than half of what I have paid for. They are not old parts either, most items have only been bought for 6~9 months and limited usage
so please, no unreasonable offers
PFC Sold!
Items still available for sale:
Stock Fuel Pressure Regulator adapter for external mounting- Good for RB25 top feed conversions without having to buy another reg
Suits: Nissan RB SR fuel regulator - maybe other cars too like subaru wrx but I'm not 100% sure
Also Inculded: Dash 6 male fitting
Price: $40
Price: $300
Front Bilsteins Sold!
rear pair still available @ $100 for the pair
Bilstein shocks rears only- Car handled really well with them, great for street cars and occasional track days.
Suits: Skyline / stagea models with eye mount at the rear. eg GTST, GTS, GT, GTS4, GT4
Condition: Good condition, No leaks, rears are about 15000km with circlip groove machined for height adjustment.
Price: $100 for the pair
Price: $40
Price: $300
http://www.sau.com.au/forums/index.php?/topic/403711-Top-Feed-Rail-In-R33-With-Stock-Plenum%2E%2Eyes-It-Can-Be-Done/page__view__findpost__p__7421431
Above is a link to the guide on how to install the top feed fuel rail with 1/2 height injectors. The fuel rail is exactly the same as what Johnny has except for the colour, so you will be able to go by this guide when doing the conversion.
Will include additional barbed fitting for the fuel reg adapter @ no extra cost so you can choose to use either the barbed hose fitting and the dash 6 fitting
Have pulled the rear shocks out, washer on strut top isn't in the best condition and the top of one of the shaft is rounded.
Top nut isn't frozen and there are no leaks however. It has been loosened so you can swap the springs over or to adjust the height
In light of the condition, Price of bilstein rear suspension is now dropped to $50, includes GTR rear springs and strut tops
Just tidying this thread up and price updates- price drop on most items refer to below
Condition: No leaks, one of the shock shaft is rounded at the top, top nut is loosened however. has with circlip groove machined for height adjustment.
Price: $50 for the pair
Top Feed Billet Fuel Rail for R33 GTS-t- Direct bolt on to the stock plenum, makes top feed conversion a walk in the park.
Follow this link for installation instructions, it is the same kit as Johnny's http://www.sau.com.au/forums/index.php?/topic/403711-Top-Feed-Rail-In-R33-With-Stock-Plenum..yes-It-Can-Be-Done/page__view__findpost__p__7421431
Suits: Bolt-on fuel rail for R33 RB25 stock plenum, using 1/2 height top feed Bosch EV14s or Siemens Deka injectors,
Price: $130 - will also throw in a generic fuel pressure reg for free. Been using this on a 280rwkw setup with no issues.
Does not come with the fuel pressure regulator
Price: $40
Splitfire Coilpacks- engine runs smooth and strong @ 280rwkw with them, update your old tired coilpacks, fixes the common misfire on boost issues
Price: $250
Coilpack sold
Price: $40
Just gone through my box of parts and found an unused fuel rail for GReddy plenum- will throw this in the sale with the other fuel rail
Top Feed Billet Fuel Rail for R33 GTS-t- 2 rails included- one for Direct bolt on to the stock plenum, makes top feed conversion a walk in the park; the other is one that works with GReddy plenum, brand new never used so you can choose the right rail for your application
Follow this link for installation instructions, the bolt on rail is the same kit as Johnny's http://www.sau.com.au/forums/index.php?/topic/403711-Top-Feed-Rail-In-R33-With-Stock-Plenum..yes-It-Can-Be-Done/page__view__findpost__p__7421431
Price: $40
