Yep they are stock for R32 GTR, but the guy I bought them from said it gave his R32 GTST a few deg negative...
Are GTR and GTST arms the same length?
What size are they ? +5mm, Stock size, -5mm, or -10mm size ?
  • 3 weeks later...
Need these gone as im moving house in a week.
Someone come and grab them.
I also have a pair of RDA front rotors for Brembos.
Will do crazy cheap deal if someone wants to come around with CASH.
Brighton East, Melbourne.
0419110004
